Bonsoir,
Voici ce que j'ai mis pour RNS510 et j'ai la commande vocale:
Il faut donc coder le module 16 (Volant Multifonction) - Coding 07
Tu as un code qui se déchiffre comme suit ( ! version logiciel)
Moi j’ai mis 001312
Codage
0?xxxxx: Driver-Assistance-Systems - D'assistance au conducteur-Systems
0 = Driver-Assistance-Systems not installed
0 = Message for Driver-Assistance-Systems active w/o Button
1 = Message for Driver-Assistance-Systems inactive w/o Button
2 = Message for Driver-Assistance-Systems active with Button
3 = Message for Driver-Assistance-Systems inactive with Button
0x?xxxx: Vehicule Type
0 = Normal
1 = Special Purpose with Multi-Function Control Module (Steer. Column. Contr. Mod. as Master)
2 = Special Purpose with Multi-Function Control Module (Multi-Function Contr. Mod. as Master)
0xx?xxx: Transmission
0 = Manual Transmission
1 = Automatic Transmission - Transmission automatique
0xxx?xx: Multi-Function Steering Wheel - Volant Multi-Function
0 = Multi-Function Steering Wheel not installed
1 = With Multi-Function Steering Wheel / without Tiptronic - Avec volant multifonctions / sans Tiptronic
2 - With Multi-Function Steering Wheel / with Tiptronic – Avec volant multifonctions / avec Tiptronic
3 = Spoke Steering Wheel – Commande vocale à partir du volant
5 = Multi-Function Steering Wheel w/o Tiptronic and w/o Push-To-Talk (PTT) installed
6 = Multi-Function Steering Wheel with Tiptronic and no Push-To-Talk (PTT) installed
7 = Multi-Function Steering Wheel w/o Tiptronic and with Push-To-Talk (PTT) installed
8 = Multi-Function Steering Wheel with Tiptronic and with Push-To-Talk (PTT) installed
0xxxx?x: Cruise Control System (CCS) and Adaptive Cruise Control (ACC)
Régulateur de vitesse Système (CCS) et Adaptive Cruise Control (ACC)
0 = Cruise Control System (CCS) not installed
1 = Cruise Control System (CCS) with 6 Positions via separate Stalk installed
Régulateur de vitesse Système (CCS) avec 6 positions via tige distinct installé
2 = Adaptive Cruise Control (ACC) with 6 Positions via separate Stalk installed
3 = Cruise Control System (CCS) with 4 Positions via Blinker Stallk installed
4 = Cruise Control System (CCS) via Multi-Function Steering Wheel installed
5 = Adaptive Cruise Control (ACC) via Multi-Function Steering Wheel installed
0xxxxx?: Rear Wiper and Board Computer - Essuie-glace arrière et Ordinateur de bord
1 = Rear Wiper not installed / Board Computer via Wiper Stalk not installed
2 = Rear Wiper installed / Board Computer via Wiper Stalk not installed
Essuie-glace arrière installé Ordinateur / Conseil par l'intermédiaire d'essuie-glace tige pas installé
3 = Rear Wiper not installed / Board Computer via Wiper Stalk verbaut
4 = Rear Wiper installed / Board Computer via Wiper Stalk installed
Moi j’ai mis 001312 car : 0xx?xxx: Transmission
Origine
Codage logiciel : 0001112
OO w OO http://www.forumpassat.fr/forum/topic/1 … 40-dsg-car
