Sujet : Relevé défauts Vagcom
hier, vidange de la passat (TDI 130) du voisin et relevé des défaut par Vagcom :
Chassis Type: 3B - VW Passat B5
Scan: 01,02,03,08,15,16,17,19,35,36,37,46,55,56,58
Address 01 -------------------------------------------------------
Controller: 038 906 019 KE
Component: 1,9l R4 EDC G000SG 4898
Coding: 00005
Shop #: WSC 05314
WVWZZZ3BZ4E001509 VWZ7Z0C7600592
1 Fault Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 35-10 - - - Intermittent
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 4B0 614 517 G
Component: ABS/ESP front 3428
Coding: 04255
Shop #: WSC 05311
2 Faults Found:
00532 - Supply Voltage B+
07-10 - Signal to Low - Intermittent
00526 - Brake Light Switch-F
27-10 - Implausible Signal - Intermittent
Address 08 -------------------------------------------------------
Controller: 3B1 907 044 K
Component: CLIMATRONIC B5GP 0010
Coding: 17000
Shop #: WSC 05311
2 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
01274 - Air Flow Flap Positioning Motor (V71)
35-00 - -
Skipping Address 15-Airbags
Address 16 -------------------------------------------------------
Controller: 1J0 907 487 B
Component: Lenkradelektronik 0002
Coding: 00008
Shop #: WSC 05311
No fault code found.
Address 17 -------------------------------------------------------
Controller: 3B0 920 849 A
Component: KOMBI+WEGFAHRSP VDO V03
Coding: 21115
Shop #: WSC 00000
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to B+ - Intermittent
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00006
Shop #: WSC 05311
Address 46 -------------------------------------------------------
Controller: 1C0 959 799 B
Component: 7X Komfortgerát HLO 0003
Coding: 00259
Shop #: WSC 05311
Address 56 -------------------------------------------------------
Controller: 1J0 035 186 E
Component: Radio BNO 0006
Coding: 05403
Shop #: WSC 05311
Au niveau du tableau de bord, les témoins d'ABS et ESP sont allumés et la température ne dépasse jamais les 70°c.
Avez vous un diag ?
EGR OFF - kit XENON 6000K
