Voilà j'ai censuré le numéro de chassis
Tuesday,21,February,2017,10:38:34:26365
VCDS Version: Release 805.0
Data version: 20080625
Chassis Type: 3C0
Scan: 01 02 03 04 08 09 10 15 16 17 19 25 42 44 46 52 53 56 62 72
VIN: WVWZZZ3XXXXXXXXX Mileage: 269820km/167658miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: Cannot be reached 1100
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: None
Part No SW: 03L 906 022 CL HW: 03L 907 309
Component: R4 2,0L EDC G001AG 6222
Revision: --H01--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 08500 995 89022
No fault code found.
Readiness: N/A
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1818
Revision: 04843012 Serial number: 00000806050277
Coding: 0000020
Shop #: WSC 05311 000 00000
Address 03: ABS Brakes Labels: None
Part No SW: 3C0 614 109 P HW: 3C0 614 109 P
Component: J104 C4 440 V2 0011
Revision: --025--- Serial number: 00000785758904
Coding: 0002325
1 Fault Found:
02840 - Can't Decode, CODE File Not Loaded!
008 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 253
Mileage: 269303 km
Time Indication: 0
Date: 2017.02.12
Time: 00:00:31
Freeze Frame:
Speed: 0.0 km/h
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 10011111
Count: 117
Hex Value: 0x0000
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 CR HW: 3C0 907 044 CR
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
1 Fault Found:
01810 - Can't Decode, CODE File Not Loaded!
000 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 6
Reset counter: 8
Mileage: 269408 km
Time Indication: 0
Date: 2017.02.13
Time: 18:05:08
Address 09: Cent. Elect. Labels: None
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008503904
Coding: E1880F0700041A00470A00000F00000000095D435C000120000000000000
Shop #: WSC 05124 000 00000
Part No: 3C1 955 419 A
Component: Wischer 130508 003 0205
Coding: 00046997
Shop #: WSC 05124
Part No: 1K0 955 559 AH
Component: RLS 230608 054 0402
Coding: 00208936
Shop #: WSC 05124
Address 10: Park/Steer Assist (J446) Labels: None
Part No SW: 3C8 919 475 HW: 3C8 919 475
Component: PARKHILFE 8K H07 0007
Revision: -------- Serial number: 97540817003503
Coding: 100103
Shop #: WSC 05314 000 00000
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPBNFLTK
Coding: 0012341
Address 16: Steering wheel Labels: 3C0-953-549.lbl
Part No SW: 3C0 953 549 AC HW: 3C0 953 549 AC
Component: J0527 0020
Revision: 00026000 Serial number: 3C9953507AR
Coding: 0001112
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 E HW: 3C0 920 871 E
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 76873 873 66865
Address 19: CAN Gateway Labels: 3C0-907-530.lbl
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600P085300D79
Coding: FDA07F060002022002
2 Faults Found:
01305 - Can't Decode, CODE File Not Loaded!
004 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01100100
Fault Priority: 1
Fault Frequency: 2
Reset counter: 20
Mileage: 215679 km
Time Indication: 0
Date: 2014.05.30
Time: 11:55:22
01304 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 20
Mileage: 215679 km
Time Indication: 0
Date: 2014.05.30
Time: 11:55:25
Address 25: Immobilizer Labels: 3C0-959-433-25.lbl
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
1 Fault Found:
02823 - Can't Decode, CODE File Not Loaded!
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 222
Mileage: 269619 km
Time Indication: 0
Date: 2017.02.15
Time: 22:37:32
Address 42: Door Elect, Driver Labels: None
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1517
Revision: 71009005 Serial number: 00000552388607
Coding: 0004279
Address 44: Steering Assist Labels: Redir Fail!
Part No SW: 5N1 909 144 G HW: 5N1 909 148 F
Component: J500__APA-BS KL.082 0401
Revision: 1AH02234 Serial number: 00081140235202
Coding: 0000258
2 Faults Found:
01288 - Can't Decode, CODE File Not Loaded!
011 - Can't Decode, CODE File Not Loaded! - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 9
Fault Frequency: 5
Reset counter: 14
Mileage: 0 km
Time Indication: 0
Freeze Frame:
CODES Not Loaded: TXT 000 049
RPM: 0 /min
Speed: 0.0 km/h
(no units): 2.0
Voltage: 12.80 V
00566 - Can't Decode, CODE File Not Loaded!
008 - Can't Decode, CODE File Not Loaded! - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 78
Mileage: 261325 km
Time Indication: 0
Date: 2016.10.27
Time: 00:09:34
Freeze Frame:
Hex Value: 0x5301
Hex Value: 0x4301
Hex Value: 0x1B01
Hex Value: 0x5601
Hex Value: 0x4601
Address 46: Central Conv. Labels: 3C0-959-433-46.lbl
Component: KSG PQ46 ELV 042 0472
Coding: 0091020051030E763004941570084F0B607801
Component: Sounder n.mounted
Component: NGS n.mounted
Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: None
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1517
Revision: 71009005 Serial number: 00000043588605
Coding: 0004278
Address 53: Parking Brake Labels: None
Part No SW: 3C8 907 801 A HW: 3C8 907 801 A
Component: J540 EPB3 VW-10498 0003
Revision: 008 Serial number: 00000000048081
Coding: 0000057
Address 56: Radio
Cannot be reached
Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000450217
Coding: 0000144
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000459579
Coding: 0000144
End ---------------------------------------------------------------------
